Fibre upgrade - upload speed increased, d/l speed static at 3mbps
FIXED- Subscribe to RSS Feed
- Fibre upgrade - upload speed increased, d/l speed ...
06-08-2016 9:44 AM
Hi, formally switched over to advanced fibre yesterday. My upload speed has increased significantly ranging from 13 to 18mbps now, but my d/l speed has stayed consistently at approx 3mbps, as it was prior to upgrade. Not aware of any issues on phone line and have hardwired into router. BT wholesale speedcheck returns an error message when i attempt to run advanced diagnostic feedback. Have restarted laptop/router, disconnected and reconnected. Can you advise?
Fixed! Go to the fix.
Re: Fibre upgrade - upload speed increased, d/l speed static at 3mbps
06-08-2016 9:51 AM
check here https://portal.plus.net/my.html?action=data_transfer_speed and if that is just above 3mb/s try chat to get it changed to match the IP profile
06-08-2016 10:07 AM
06-08-2016 10:52 AM
All hunky dory now, many thanks for fast service Matt.
06-08-2016 10:59 AM
