Fibre upgrade - speedtest speeds much lower than router/Plusnet stats
- Fibre upgrade - speedtest speeds much lower than ...
13-01-2016 11:05 AM
I've been upgraded to 40 Mbps fibre from ADSL today and am using the Plusnet Hub One.
The router gives stats thus d/l 39.06, u/l 1.95
Plusnet's website shows current linespeed 37, estimated linespeed 40 (this may vary between 21 and 21)
BT speedtest, though, gives d/l 23.01, u/l 1.82, ping 35.75.
Could anyone explain. please why I'm only getting just over half of what appears to be the speed coming to the modem?
Message 1 of 7
(1,083 Views)
6 REPLIES 6
Re: Fibre upgrade - speedtest speeds much lower than router/Plusnet stats
13-01-2016 1:47 PM
I would not worry to much about the bt speed test never has been much good try www.speedtest.net ; and see what you get
Message 2 of 7
(760 Views)
13-01-2016 1:55 PM
@lfaulkerner
Are you testing using WIFi or via an Ethernet cable connecting the PC to the router?
If WiFi, then please try using a cable to see if you are getting a higher speed. WiFi speeds are notoriously difficult to speed checker reliably and prone to interference.
Also as the BTW test is the one Plusnet will require to run when logging a fault, I would just keep run that one.
Message 3 of 7
(760 Views)
13-01-2016 2:38 PM
"I would not worry to much about the bt speed test never has been much good try www.speedtest.net ; and see what you get"
It's similar - u/l 22.75. d/l 1.88
I am using a cable connection. Do you think a disconnect and reconnect might help? I was reluctant to do do this as, with ADSL, I know there is a learning period - not sure if it is the same with fibre.
The thing I don't understand is why the router is reporting nearly 40. which I would expect, being only a few yards from the exchange, yet I'm actually getting nor much more than half that.
Message 4 of 7
(760 Views)
13-01-2016 2:52 PM
There is no 10 day learning period for FTTC, so log onto the router press disconnect, wait a few minutes and press connect. Worth a try.
Message 5 of 7
(760 Views)
13-01-2016 3:29 PM
No joy, I'm afraid. D/l now 22.92 after reboot.
Message 6 of 7
(760 Views)
13-01-2016 4:05 PM
Well that leaves http://community.plus.net/library/broadband/broadband-faults-guide-i-have-a-fault/
Message 7 of 7
(760 Views)
