Fibre upgrade - speed slower
mrsadavies
Hello
I upgraded to Fibre today.
My download speeds are now even slower than they were.
They were 1Mbps they are now 0.34Mbps.
What's going on?
Fixes: 167
Re: Fibre upgrade - speed slower
It's likely that the new speed profile hasn't come through to our systems yet, I'll update this manually and you should be getting the new speeds within a few minutes. If not, try logging in to your router and pressing disconnect/reconnect.
 Chris Parr
 Plusnet Staff
mrsadavies
Yes
That seems to have sorted it.  Just done a speed check and Download speed is now 31.95Mbps.  Smiley
I had reported it as a fault before I found this forum.  Can you cancel the fault report?
Fixes: 167
Looks like you got there before me and closed it off Smiley
Welcome to the forums and please let us know if we can help any further.
 Chris Parr
 Plusnet Staff
