Fibre upgrade - speed slower
- Fibre upgrade - speed slower
14-11-2014 2:32 PM
Hello
I upgraded to Fibre today.
My download speeds are now even slower than they were.
They were 1Mbps they are now 0.34Mbps.
What's going on?
What's going on?
Message 1 of 4
(595 Views)
3 REPLIES 3
Re: Fibre upgrade - speed slower
14-11-2014 2:42 PM
It's likely that the new speed profile hasn't come through to our systems yet, I'll update this manually and you should be getting the new speeds within a few minutes. If not, try logging in to your router and pressing disconnect/reconnect.
Message 2 of 4
(317 Views)
14-11-2014 3:05 PM
Yes
That seems to have sorted it. Just done a speed check and Download speed is now 31.95Mbps.
I had reported it as a fault before I found this forum. Can you cancel the fault report?
Message 3 of 4
(317 Views)
14-11-2014 3:08 PM
Looks like you got there before me and closed it off
Welcome to the forums and please let us know if we can help any further.
Message 4 of 4
(317 Views)
