Fibre upgrade, no faster
Mrjenx
I have moved house and upgraded to fibre which was installed earlier.  I have just done a line test and I'm only getting 5mb down which is worse than before!
Does it take a while for the speed to improve or do I need to be doing something different?
nonamesleft
Re: Fibre upgrade, no faster
did you use this site http://www.speedtest.net/ ; i used the plusnet speed check and it said it was only 2mb but 38 on speedtest.
Mrjenx
Sorted.
Quick chat with someone and it turns out the house move hadn't been completed so still had my old profile etc.
