Fibre upgrade, no faster
- Fibre upgrade, no faster
08-01-2015 6:49 PM
I have moved house and upgraded to fibre which was installed earlier. I have just done a line test and I'm only getting 5mb down which is worse than before!
Does it take a while for the speed to improve or do I need to be doing something different?
Message 1 of 3
(594 Views)
2 REPLIES 2
Re: Fibre upgrade, no faster
08-01-2015 7:11 PM
did you use this site http://www.speedtest.net/ ; i used the plusnet speed check and it said it was only 2mb but 38 on speedtest.
Message 2 of 3
(367 Views)
08-01-2015 7:34 PM
Sorted.
Quick chat with someone and it turns out the house move hadn't been completed so still had my old profile etc.
Message 3 of 3
(367 Views)
