Fibre upgrade completed, but speed still as before
ccarmock
Hi,   I see that my upgrades from ADSL2+ to fibre completed today as expected.  However I did get a note from PlusNet last week to say this had happened but it had not.
What I see now is the router is reporting VDSL2 and is in sync at 32.4 Mb/s  however I am getting around 12 Mb/s speeds, and when I look at https://portal.plus.net/my.html?action=data_transfer_speed   I see this is reporting a line speed of 12.9 Mb/s which is not right, but that is what it was before the fibre upgrade.
I have seen other reports where some automated task fails.  Could you help to reset the line speed to match the sync speed please?
Fixes: 165
Re: Fibre upgrade completed, but speed still as before
I've sorted that out for you now, you'll probably need to disconnect/reconnect once and then you should be good to go.
 Chris Parr
 Plusnet Staff
ccarmock
Perfect thank fixed it!  thank you!
