Fibre to Fibre Extra
Fixes: 131
Re: Fibre to Fibre Extra
Well it shows the upgrade did go through, but your sync speed is quite low.
I'm afraid it doesn't. The Max observed speeds on the wholesale checker are not necessarily  an indication that the product has been changed.
I don't know how they are obtained but I suspect they are calculated during some form of test, not real ones. For example my line says
Max Observed Downstream Speed 68.72
Max Observed Upstream Speed 17.91
Observed Date 2020-04-10
but I am NOT on Fibre extra and never have been , my actual sync speeds are 40 down and 10 up and always have been.
Fixes: 50
@Leapy  for FTTC/VDSL a filtered master socket should be fitted and will give the best performance, and extensions don't need filters.
ADSL is less fussy so if no filtered master socket, all extensions with phones should have a filter.
Seasoned Pro
@MisterW I am Fibre Extra and mine are not as good as your 40 down 10 up actual.
These are tests today the BT one is my limits of 35 down and 20 up, but the actual is not as good as yours and the other 12 are hourly snapshots, all with very little else running.
BT WholesaleBT WholesaleHourly snapshotsHourly snapshotsPN average over 12 hoursPN average over 12 hours
Seasoned Pro
@Mustrum wrote:
@Leapy  It should be totally quiet - any noise is likely to lead to a reduction in broadband speed.
On your DSL checker, the Max observed speeds show that it is pointless going to Extra as the speeds are under 40/10.
You line is cable of a lot more, so you should be going through the diagnostics to help diagnose your issue.
@Mustrum I have been on PN  Fibre Extra (from PN Fibre) for 11 months and it seems no different to the basic PN Fibre (other than higher cost)
On 17070 quiet test you I can't hear any noise, which I think is good 😊
The limited diagnostics I can do in Admin and line checking, and moving kit, filtering or disconnecting bits, make no difference, so I guess consistency is good? 🙄
Seasoned Pro
@AdrianP @Mustrum @MisterW  I have just raised my low speeds as a fault to get it looked at  https://portal.plus.net/apps/kbdfaults
@AdrianP  it would be ironic if they suggest a new router for EXTRA would fix the problem Cheesy
