Fibre to Fibre Extra - How long does it take to get the line speed change?
FIXED- Subscribe to RSS Feed
- Fibre to Fibre Extra - How long does it take to ge...
02-11-2018 9:07 PM - edited 02-11-2018 9:07 PM
Hey All,
So, I upgraded to Fibre Extra from Fibre earlier this week. I got an e-mail yesterday saying that the product change was complete product change was completed.
I have rebooted the router a few times. I'm still only getting 37Mb down, which is exactly the same as before the upgrade. My router is still synced at 39.9Mbps down.
Was promised more like 50 - 60 Mbps when upgrading, have read about others lines needing a bit of a shove to get the upgrade, is this the case here? If it's topped out at 39Mbps I'll roll back the order as there is no point in paying the extra.
The current line speed in the member's centre is reading '80Mb', BTWS line stats attached.
Thanks in advance.
Fixed! Go to the fix.
Re: Fibre to Fibre Extra - How long does it take to get the line speed change?
02-11-2018 10:27 PM
Moderators Note
This topic has been moved from Broadband to Fibre
03-11-2018 11:21 AM
You may need your ip profile reset at PN's end hopefully one of the bods that frequent the forum will notice, if nothing changes raise a fault and ask them to check the ip profile
03-11-2018 11:24 AM
Are you by any chance on a fixed IP address? The reason I ask is because Plusnet need to raise your profile on their system on these accounts and sometimes overlook it..
03-11-2018 3:20 PM - edited 03-11-2018 3:20 PM
No, regular dynamic assignment.
Fingers crossed someone relevant sees this post and resets it for me 🤞
05-11-2018 10:45 AM
Sorry to hear this.
It looks like only the account on our end changed and no order was sent through to our suppliers to change the profile
I've done this for you now and it should complete tomorrow
Let us know if you're still having issues after
13-11-2018 7:40 AM
Thanks Matt, now up to 71.9Mb/s, much better 😀
13-11-2018 2:31 PM
That's great @olsgreen, please let us know if you have any further issues.
