Fibre sync sped dropping day by day
r18rws
Started service getting the full 80/20. Was syncing on my router stats as 79999/19999 and plusnet speed rate on member centre showing a current speed of 79.
Dropping every day but because of disconnects. Seem to be getting the connection throttled or something.
Is there a way to get reset again as reboot seems to make the connection get worse not better so trying to avoid that.
On plusnet site the current speed is down to 71.4 now. My router stats are also dropping and a Speedtest also slowing down.
Fixes: 167
Re: Fibre sync sped dropping day by day
There have been a couple of disconnections, but nothing too major:
Your line is currently connecting at:
Sync Status In Sync
Downstream Speed 73.4 Mbps
Upstream Speed 20.0 Mbps
And the estimates are:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 77.7 60 20 17 -- Available -- --
Unfortunately as you're well within the estimate range this wouldn't be accepted as a fault and we cannot remotely reset or change line settings on FTTC.
 Chris Parr
 Plusnet Staff
r18rws
Thanks Chris, will keep an eye on it and see if it continues to drop, hopefully might go in the opposite direction again.
Oddly enough the speedtest site has started to identify me as BT now instead of Plusnet.
Outages - Sunday 11am-1pm ish I understand - power off for some work, and also the Tuesday 8pm ish router restart after update, the others are unexpected. Tues early hours looked like quite a big offline period 15-30mins or so?
