Fibre stuck at 40mpbs?
seatmad
Hello,
Hoping someone can help. I'm with Plusnet for my Fibre Broadband on the Unlimited Fibre extra package so to my understanding that should allow me to get speeds of up to 76mpbs if my line supports it. Now when I first got my broadband installed over a year ok it was originally around 55mbps before dropping down to 50mbps as it stabilised. This all ties in with the BT DSL checker page which shows I should get up to 55.8mps.
How ever recently my line snyc speed is always at 40mbps (or 39.999 if we want to be accurate). This is even after say a power outage or router restart. Has anyone get any ideas as to why as to me it seems very odd to be bang on 40mpbs which is plusnets lower fibre package even after the line re syncs. Is it possible that I've been dropped down somehow or is that just what my sync speed is.
Many thanks
Plusnet Staff
Plusnet Staff
Fixes: 6
Re: Fibre stuck at 40mpbs?
Hi there! Sorry for the issues you are having.
I have ran a test and this is detecting a possible External Fault. I have raised this to our Suppliers and we should have an update in the next 72 working hours. You can monitor this on Ticket:164906491 Smiley
 Lauren Barry
seatmad
Thanks very much. I will await the update
Fixes: 385
It looks like an engineer visited you yesterday and renewed your master socket, but testing your line again is showing a potential external fault still so I've sent the fault report back to our suppliers to further investigate.
