Fibre speeds
FIXED- Subscribe to RSS Feed
- Fibre speeds
- « Previous
- 1
- 2
- Next »
Re: Fibre speeds
21-11-2019 10:19 AM
Thanks for your post, @Ron84.
We're sorry to hear of these speed issues.
On checking the line, we're detecting a potential bridge tap, which is essentially an unterminated bit of cable that can cause a fair few issues in communications lines.
We'd firstly recommend setting the connection into the test socket to see if this removes the bridge tap from the equation and to also see if the speeds increase. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Please let us know how it goes.
Re: Fibre speeds
21-11-2019 4:31 PM
I conducted the test directly from the test socket as advised. This showed no change to download speed and removes a bridge tap from the equation. However, following the test, my download speed has fallen even further to 14.64 Mbps, a long way from the rock solid 33 Mbps I am used to (FTTC).
I suspect it's not relevant, but smartmeters were installed over this time period. Next steps?
Re: Fibre speeds
21-11-2019 4:53 PM
Re: Fibre speeds
21-11-2019 6:00 PM
hello i was wondering if plusnet can do some tests on my line please or see if there anything wrong still not happy with the speeds im getting i know yesterday i said it maybe my WiFi adaptor on my PC but iv been doing some speeds tests on my phone when im right next to the router and im getting poor speeds, changing channel doesn't seems to help and my router is already connected to the test socket. thanks
Re: Fibre speeds
21-11-2019 7:38 PM
Hey there @mike360,
Thanks for reaching out to us here.
I'm sorry you are having trouble with your speed and I apologise for the frustration caused.
What speeds are you seeing over the test? I would advise getting a device connected via Ethernet & testing while you are connected to the test socket and let us know the results.
Thanks.
Re: Fibre speeds
21-11-2019 9:00 PM
Re: Fibre speeds
22-11-2019 10:34 AM
Thanks for getting back to us @mike360
It may be that something has been introduced in your property or around your property which could be causing wireless interference.
I'd recommend downloading a WiFi analyser app to see what wireless channel is best in your area and then change the wireless channel in yout router to that one.
Let us know how you get on
Re: Fibre speeds
22-11-2019 10:41 AM - edited 22-11-2019 10:44 AM
ive plugged in my old router plusnet hub and the speeds are still same 40+Mbps via WiFi can you GEA test thingy please, also this router needs a firmware update if there is one. thanks
Re: Fibre speeds
22-11-2019 1:55 PM
- « Previous
- 1
- 2
- Next »
