Fibre speeds lower than expected
FIXED- Subscribe to RSS Feed
- Re: Fibre speeds lower than expected
02-08-2018 3:21 PM
I signed up with Plusnet at the end of June, and eventually got connected at the start of July, however I don't seem to be able get a sync speed above 65mbps.
Looking at my line stats, the difference between the max attainable rate (77469) and sync rate (64863) seems quite high, so i'm starting to wonder if the line is capped or something? maybe DLM? The cabinet is pretty close to the house too, so i'd expect something in the higher 70s.
I've tried connecting the router directly to the Master socket but it still syncs at 64/65mbps so it's definitely not my modem lead etc.
I tried running a BT Wholesale performance test but everytime I do it (on different days & browsers) I get 'The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.'
Can someone check my line and see why i'm unable to get a higher sync speed.
screenshot of my specs attached.
cheers,
Laurence
Fixed! Go to the fix.
02-08-2018 3:36 PM - edited 02-08-2018 3:37 PM
I found this link - https://portal.plus.net/my.html?action=data_transfer_speed&_ga=2.127648333.1167416515.1533217153-341...)
which shows the following:
02-08-2018 6:40 PM
Hi Laurence.
I've had a look into this for you and from what I can see, whilst you have an active connection your order is actually still open on our suppliers systems. Ideally this should've been checked before your ticket was closed.
This means that we can't run a test or raise a fault on your fibre service and also likely explains why you're unable to complete a performance test.
I've got in touch with BT now and I've been advised that the order should complete within 24 hours.
I've raised a ticket on your account to my teams workflow to follow up afterwards.
03-08-2018 3:56 PM
thanks Anoush!
I received a reply from one of your colleagues, but I'm a bit uncertain whether or not to go ahead with the engineer visit based on this line:
If the engineer finds the problem is with your internal wiring, your equipment, the condition of your property or the Openreach network has been damaged within the boundary of your property by things like building or garden works or if no fault is found, you will receive a charge of £65 to cover the cost of the engineer.
Can you run a GEA test to tell me what the expected speeds should be from my line?
I don't want to have to pay £65 if the engineer finds no fault and the speeds are as much as I can get!
thanks,
Laurence
03-08-2018 4:39 PM
No problems Laurence. As we can see your speeds are below where they should be it'd be unlikely we'd charge you if there was no fault found. We'd just send out another engineer to investigate further if things remained the same.
03-08-2018 4:45 PM
thanks again, do you have the results from a GEA test?
03-08-2018 5:03 PM - edited 03-08-2018 5:03 PM
Yeah sure, here you go:
Test Outcome | Pass | |
Test Outcome Code | GTC_FTTC_SERVICE_0000 | |
Description | GEA service test completed and no fault found . | |
Main Fault Location | OK | |
Sync Status | In Sync | |
Downstream Speed | 65.1 Mbps | |
Upstream Speed | 20.0 Mbps | |
Appointment Required | N | |
Fault Target Fix Time | ||
Fault Report Advised | N | |
Estimated Line Length In Metres | 205.3 | |
Upstream Rate Assessment | Very Good | |
Downstream Rate Assessment | Low | |
Interference Pattern | Not Detected | |
Service Impact | No Impact Observed | |
Home Wiring Problem | Not Detected | |
Downstream Policing Discard Rate | 0.0 | |
Customer Traffic Level | Upstream and Downstream Traffic Detected | |
Technology | VDSL | |
NTE Power Status | PowerOn | |
Voice Line Test Result | Pass | |
Bridge Tap | Not Detected | |
Radio Frequency Ingress | Not Detected | |
Repetitive Electrical Impulse Noise | Not Detected | |
Cross Talk | Not Detected | |
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off | |
Time Stamp | 2018-07-24T15:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 64.6 Mbps | 65.0 Mbps | 64.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 633.0 Sec | 900.0 Sec | 899.6 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-08-03T13:45:07Z | 2018-08-03T14:00:07Z |
Ingress Code Violation | 1 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
05-08-2018 11:10 AM
Not sure what changed as my setup hasn't, but I'm not complaining!
Cheers,
Laurence
06-08-2018 11:46 AM
06-08-2018 6:16 PM
it's actually gone higher again today
syncing at 79023! I think that's my lot lol
06-08-2018 6:18 PM
