Fibre speeds haven't updated
- Fibre speeds haven't updated
15-06-2017 4:07 PM
Long story short:
I was on Unlimited Fibre Extra, was downgraded to Unlimited Fibre by mistake, was put back onto Unlimited Fibre Extra but the speeds haven't been updated.
My line CAN handle the extra speed as it has been doing for 2 years (70mb). But now it's stalling at 36-38mb which is frustrating. I checked these results on the BTW Performance Test. Attachment shows the results.
Can one of the agents please bump it back up to the proper speeds?
Re: Fibre speeds haven't updated
15-06-2017 4:25 PM
Sorry to hear you're having speed issues.
Testing your line is showing your router in sync at 40/2.
Sync Status | In Sync |
Downstream Speed | 40.0 Mbps |
Upstream Speed | 2.0 Mbps |
It looks like it's not a profile issue on your account. The provisioned product with our suppliers hasn't been changed.
I've now placed an order to modify your service, which should complete tomorrow.
Let us know if you have any further issues.
15-06-2017 4:27 PM
Thank you, I take it then that it will be fixed tomorrow?
I'll update you if there's any issues.
15-06-2017 4:34 PM
