Fibre speeds dropped, new install
FIXED- Subscribe to RSS Feed
- Fibre speeds dropped, new install
02-10-2018 8:10 PM
My Fibre went live on Friday, and on the first day it measured as:
But it only lasted for about a day, and since then has been at:
Fixed! Go to the fix.
Re: Fibre speeds dropped, new install
02-10-2018 8:20 PM
Your speeds haven't dropped well the sync hasn't infact it's increased your Profile is 77.34Mb, I would test with an another tester the BTW one has it's issues and very rarely gives a proper result these days.
02-10-2018 8:23 PM
Been testing each night with Speedtest.net, get the same results
02-10-2018 8:27 PM
OK are you testing over a wired or wireless connection, if it's wireless can you try a wired connection.
If it's a wired connection then it could be that the profile on Plusnets end isn't set correctly and would need adjusting.
02-10-2018 8:31 PM
Wired, I definitely think theres something odd going on on PLusnets side, since its been steadily at around 22mbps
03-10-2018 1:21 PM
Hi there.
Our tests aren't showing any issues. Are you able to replicate the problem using a different device?
Failing that I'd report a fault to us at http://faults.plus.net so we can pass this on to our suppliers for further investigation.
03-10-2018 7:07 PM
Well I have been testing all night, and noticed I was getting full speed over Wifi, so I swapped out the cables between devices and the speed has gone back up. So looks like a hardware issue on my end, thanks anyway
04-10-2018 11:44 AM
