Fibre speeds compared to neighbours
- Fibre speeds compared to neighbours
07-03-2021 8:09 AM
Re: Fibre speeds compared to neighbours
07-03-2021 9:56 AM
@barnettmoore276 Welcome to the forum.
The immediate smart Alec answer is “move house”.
The difference may be due to when the houses had a telephone installed. There was a period, I think in the 70s when there was a shortage of copper and BT used aluminium cored telephone cable. If you are unlucky enough to be wired in this then it could be the cause of the problem, even if the cables follow the same route as copper connected neighbours. If you are in this unfortunate position I suspect that you will have to await FTTP before your fault free speed improves.
07-03-2021 5:45 PM - edited 07-03-2021 5:48 PM
Don't judge your neighbours speed based on the BT checker, its very optimistic. Unless of course you mean the Max Observed Downstream Speed which is accurate, although also check the Observed Date to see how recently that was updated.
I have two landlines, one with Zen and one with Plusnet. Both barely stay above the Handback threshold for a clean line, and my lines are just over 200m to the cabinet.
Both lines used to have full sync speed originally, they have reduced over time due to other customers getting broadband, causing crosstalk.
