Fibre speeds & IP Profile
- Fibre speeds & IP Profile
- « Previous
- Next »
Re: Fibre speeds & IP Profile
09-03-2015 7:50 PM
09-03-2015 7:58 PM
http://www.thinkbroadband.com/speedtest/results.html?id=142593090740853769518
10-03-2015 7:04 PM
http://www.thinkbroadband.com/speedtest/results.html?id=142601361385081563630
11-03-2015 4:28 PM
11-03-2015 5:28 PM
11-03-2015 5:54 PM
12-03-2015 6:46 PM
You mentioned a couple of times about the Leyburn exchange suffering congestion, and that my exchange is connected through this (is there anywhere I can see this btw, just for interest?), well I just got off the phone to one of my friends who lives in Leyburn and is also a PlusNet customer. He is suffering from the exact same issues I am at peak times. He goes from around 68mb speeds during the day to around 5mb after 6pm. He's raised it as a fault a few days ago and I can pm his username if needed, but does this information help or shed any further light on the matter? I'll add this info into my fault ticket just in case.
12-03-2015 7:14 PM
Yeah, that is useful information. Hopefully one of the CRT guys can pick this up because your issue is almost certainly part of the same problem. I would also add the information to your fault ticket so the faults guys can also see this, and mention your exchange is a child of Leyburn.
Unfortunately, the parent/child exchange list for FTTC is behind a password protected site with BT Wholesale. Leyburn is the parent exchange of quite a few child exchanges though.
12-03-2015 11:11 PM
16-03-2015 10:04 AM
"Its contention and your CP throttling you because they can't the amount of customers they have, apparently PlusNet are notorious for it."
His words, not mine! I then mentioned about the TAP 3 tests being terrible and that supposedly bypassed Plusnets network (do correct me if I'm wrong) to which he said it could BTW then. That's actually the first time I've heard that BTO and BTW aren't the same outfit so I guess I learned something today
So the quest continues and I'm getting less and less confident in who to believe and losing faith that this will be cleared up anytime soon.
However...speeds and latency on an evening have actually been good since Friday 13th! There were a couple of disconnects during the day (I think a lot of folks were affected if I read the service page correctly) but the evening latency was fine. So I've started keeping a log of which evening was good and which were bad. I should have started this weeks ago, but as all evenings were pretty bad it didn't occur to me. Anyway, while it has been good the two nights I used it, both time I was on the ptw-bng02 gateway.
Edit: Didn't look close enough - the ptw-bng02 was the good one I've been on over the weekend, am now on the pcl-bng02 gateway after the modem was dc'd this morning for the engineer tests. Will be interesting to see how the speeds are this evening.
16-03-2015 10:14 AM
The evidence shows it to be an issue within the BTw network based on the TAP3 test results and your neighbours being with a different CP but seeing the same issue.
16-03-2015 10:20 AM
17-03-2015 9:11 AM
- « Previous
- Next »
