Fibre speeds & IP Profile
- Fibre speeds & IP Profile
Re: Fibre speeds & IP Profile
01-02-2015 7:16 PM
Using their alternate speedtester I got a graph with 2 lines on, see above. Does this make any more sense?
01-02-2015 7:37 PM
What about the BT Speed Tester http://speedtest.btwholesale.com/ - can you run that and the Further Diagnostics ? What's your current line speed here https://portal.plus.net/my.html?action=data_transfer_speed ? Which exchange are you on?
01-02-2015 7:59 PM
Attached are two screenshots from the BTwholesale tester - with further diagnostics and then even further connect as speedtest@speedtest_domain
01-02-2015 8:10 PM
I think we've ruled out an issue your end (network wise) and the TAP3 result rules out an issue Plusnet's end.
It looks like there is possibly a congestion issue. Your exchange is connected to Leyburn which does have a capacity issue on one link. Plusnet will be able to run some tests on your connection and see if you're on that affected link. Have you raised a ticket at http://faults.plus.net yet?
01-02-2015 8:14 PM
01-02-2015 8:21 PM
02-02-2015 11:04 AM
03-02-2015 9:02 PM
06-02-2015 3:53 PM
06-02-2015 6:45 PM
07-02-2015 4:04 PM
07-02-2015 8:36 PM
09-02-2015 9:14 AM
09-02-2015 10:07 AM
Just had the engineer visit. Nice guy and very helpful, but as expected the line tested fine. He figured it was just doe to very high demand on the exchange (or somewhere in the network) at peak hours. I'll wait to hear back from you guys though.
17-02-2015 8:51 PM
http://www.thinkbroadband.com/speedtest/results.html?id=142420591016523570624
