Fibre speed
Davemorris1951
Fibre speed
Good morning,
i set set up my hub one around 12 hours ago for my new fibre connection and it's saying my downstream is only around 17mb which doesn't seem quite right as I was getting that on my old adsl service, any idea what might be going on?
thanks for any help
rongtw
Fixes: 12
Re: Fibre speed
Hi , your switch over may have not been completed by Plusnet yet , Hopefully one of the staff will check this when they arrive Thumbs Up
Davemorris1951
Re: Fibre speed
Just a note to add that I forgot earlier, when I did a bt wholesale speed check last night it said the maximum line speed was only 16.99mb which certainly doesn't seem right, not sure if this is part of the problem or can be changed etc?
Davemorris1951
Re: Fibre speed
Any chance this can be looked at?
Fixes: 13
Re: Fibre speed
It sounds to me like the fibre connection is still waiting to go live. If you send me a private message with your Plusnet username, I'll be able to take a look at this for you and see what's going off.
 Dean R
 Plusnet Staff
Davemorris1951
Re: Fibre speed
Thank you, I've sent you a PM
Davemorris1951
Re: Fibre speed
Morning all,
I've had this response on my question and was just wondering what it means.
The Question 163728264 has been released from hold and sent back to CSC - FTTC Faults - Intermittent
Your fault Ticket has now been taken off hold.
This has now been forwarded to the relevant support team. We will carry on investigating your problem and your open fault will be updated as soon as more information is available.
[INTERNAL]
Ticket now off hold. Please action
Davemorris1951
Re: Fibre speed
Any update for this ticket number yet?
Fixes: 506
Re: Fibre speed
It looks like we've got an engineer booked in for Wednesday.
Can you let us know how it goes?
Davemorris1951
Re: Fibre speed
I shall do yeah, thanks
Davemorris1951
Re: Fibre speed
An update - from what I gather from someone who was at home when the engineer arrived this morning he said he couldn't find a fault with the line and the speed I'm getting must be the speed I'm supposed to get, so I'm not sure if this is accurate or not, obviously I've seen no report or anything but I'm hoping openreach will feed something back to you guys at plusnet and then you can tell me what the situation is.
Fixes: 229
Re: Fibre speed
I'm looking into this for you.
[edit]
The engineers notes don't really say much aside from he wasn't able to find a issue.
Our faults team will continue looking into this as we may need to send another engineer for a second opinion
 Matthew Wheeler
Davemorris1951
Re: Fibre speed
Ok thank you
