Fibre speed
- Fibre speed
Fibre speed
06-12-2021 12:19 PM
Fibre has been slow recently, prior to moving my landline to plus in Feb I was connecting at approx 65Mbs down speed ( cabinet is approx 250m from house) recently the speed has dropped to 35Mps down & 18 up, have reset the router ... no change. Main pc is connected direct to the router via LAN cable. numerous speed tests give the same results.
Connection has gone from very good to merely satisfactory .... any ideas?
Re: Fibre speed
06-12-2021 12:25 PM
@glassi Welcome to the forums. Hopefully, one of the Plusnet Help Team will get round to this topic in time, but fellow Community members may be able to help.
If you can post screen shot results of the following, it will give us a start:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection please report the 'Additional Diagnostics', and sight of the Help Desk tab from your Hub would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
Re: Fibre speed
06-12-2021 12:26 PM
@ Welcome to the forum.
If your speed is less than your contract minimum guaranteed speed then report it at https://faults.plus.net.
Re: Fibre speed
06-12-2021 3:36 PM
Hiya @glassi, thanks for getting in touch.
I am really sorry for the issues with your speed and for the problems caused.
I have tested your line and we are seeing a sync speed of 59.5mb with no faults being highlighted.
As you aren't seeing these speeds over a wired connection, we may need to look at sending an engineer. Do you get similar results when testing off another device (if able to)?
I have logged the fault for you here: https://www.plus.net/wizard/?p=view_question&id=220210194 and if you add a reply, just give us a nudge on here and we can pick that up for you.
Re: Fibre speed
18-12-2021 2:56 PM
Hi .... Ive changed a couple of things on the internal network and the speed test is now reporting 54.83Mbps up & 20.84 down, still not as fast as I was getting but a lot better than last week. Thanks for your help
Re: Fibre speed
19-12-2021 2:13 PM
Thanks a lot for getting back to us @glassi and I'm glad to hear that the changes you've made have resulted in your speeds coming back up. Just out of curiosity, what did you change that lead to almost a 20Mbps increase?
To be honest, 54Mbps sounds about right, your throughput speed is usually 90 - 95% of the sync speed, so I don't think there ar any problems really. Let us know if you do have any further issues though and we'll be happy to investigate.
