Fibre speed very slow
- Fibre speed very slow
03-08-2015 10:32 PM
My fibre speed is very slow - I'm on the up to 76mbps package but I rarely get close to 30mbps since I moved over from BT.
I rather naively assumed Plusnet was providing me with what I had paid for - to the point of replacing my home hub 5 with a BT openreach modem connected to a brand new ASUS AC87U router. I'm sitting 5 feet away from the router now and the speed is just hovering at 30mbps (when I was with BT directly it never went below 56mbps - and that was at it's lowest, it was usually in the 70-71mbps range).
I really need you to look at my line and get my speed back up to what I was getting with BT. If you can't do that, then I need you to "make it right" in terms of the service I have paid for but not received, and let me out of my contract so I can get my broadband back up and running properly.
Please let me know if you need more information from me.
Message 1 of 7
(1,007 Views)
6 REPLIES 6
Re: Fibre speed very slow
03-08-2015 10:35 PM
how about the result from here - IP profiles only as the upload speed result is garbage http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do and also the Plusnet Current Line Speed - se my sig for a link
Message 2 of 7
(639 Views)
03-08-2015 10:46 PM
thanks for coming back so quick!
Here's my TAP3 (will send the extra info in next post):
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
46.45 Mbps
0 Mbps 69.67 Mbps
Max Achievable Speed
Download speedachieved during the test was - 46.45 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-69.67 Mbps .
Additional Information:
IP Profile for your line is - 69.67 Mbps
Upload Speed
3.09 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 3.09Mbps
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test.
FAQ
Download Speed
46.45 Mbps
0 Mbps 69.67 Mbps
Upload Speed
3.09 Mbps
0 Mbps 20 Mbps
Message 3 of 7
(639 Views)
03-08-2015 10:47 PM
I ran it a couple of times, 46 was the highest (36 was the second highest, the standard test maxed at 30mbps).
Message 4 of 7
(639 Views)
03-08-2015 10:52 PM
For the sake of checking a few sources I just ran the test at www.broadbandspeedchecker.co.uk, which connected to a server in Maidenhead, and gave me a result of 80.35 Mb/s. Surely that isn't possible? (Upload 27Mb/s).
Confused now
Confused now
Message 5 of 7
(639 Views)
04-08-2015 4:44 AM
Lol that website is garbage.
Totally accurate
Stick with ThinkBroadband or better yet don't use any speedtest which is flash based as at the end of the download/upload they usually spike and give you something innacurate.
Totally accurate
Message 6 of 7
(639 Views)
04-08-2015 11:48 AM
If your speeds are consistently below the estimates we provided for your line I'd strongly recommend reporting this to us as a fault. Without doing so there's little we can do to help, you can report faults directly to us at https://faults.plus.net
Message 7 of 7
(639 Views)
