Fibre speed slowing
idonno
Champion
Fixes: 6
Fibre speed slowing
Following the recent snow we had a couple of days where the electricity was going on and off (auto re-closure). The electricity company seem to have finally fixed the fault but I see my sync speed seems to have dropped. As the cabinet also lost supply I'm surprised it didn't leave things are it was when it came alive again. It was about 72Mb a couple of months ago, now down to just over 65Mb. Any chance of giving it a shove?
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
5 REPLIES 5
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: Fibre speed slowing
It's totally under the control of the Openreach DLM system, PlusNet can do very little about it. The FTTC cabinets have battery backup so it would have seen your power outages. Your sync speed may recover but difficult to say how long it might take.
Fixes: 419
It's probably been slowed by the DLM increasing your SNR. This is an automatic process that can't be 'shoved' back. If you're patient and leave it be it should recover on its own but timing can be a bit variable.
MatthewWheeler
Fixes: 479
Sorry to hear your speeds have dropped.
I've tested your line and you're not actually being capped by DLM as your profile is "0.128M-80M Downstream 5dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off"
It could well be crosstalk causing this which is interference from other fibre lines. Unfortunately there's not much we can do regarding this.
 Matthew Wheeler
idonno
Champion
Fixes: 6
Thanks for the info. I'll see what happens. DLM seems to be very active lately. I liked it when the speed was going upwards 🙂
Fixes: 1,600
No problems. Fingers crossed your speeds increase.
