Fibre speed only 5megabits..
- Fibre speed only 5megabits..
29-08-2017 4:41 PM
All downloads, speedtests etc are showing ~5megabits.
- Using Wifi? – If you are, we need to first of all find out if the issue is due to the connection between the exchange and your router or your router and your devices. For example the connection may be fine and you may need to investigate a problem with your wireless connectivity. The simplest way to do this is to connect a PC or other compatible device straight to the supplied router using a network cable. Please then compare your speeds to that of using WiFi before going through the next steps.
I am plugged into my router directly. It is a netgear nighthawk R7000.
- Result of a BT speedtest http://speedtest.btwholesale.com/ and then Further diagnostics for the IP profiles.
This video explains exactly what to do
Download speed 4.62, Upload speed 8.36, Ping 23.
Further diagnostics says :
Download speedachieved during the test was - 4.62 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-68 Mbps .
Additional Information:
IP Profile for your line is - 68 Mbps
- Current Line Speed from here(Please note that there is not an equivalent for Madasafish customers)
Estimated line speed:There's no speed estimate currently held on your account.Current line speed:71.4 Mb
Re: Fibre speed only 5megabits..
30-08-2017 9:58 AM
Checks against your line don't show any problems but if this is still an issue I'd report a fault over at http://faults.plus.net
