Fibre speed only 1/3 of guarantee
wid
In the Broadband section of my plusnet account, I see this:
  • Product: Unlimited Fibre Extra
  • Estimated Download Range: 67 - 72Mbps
  • Estimated Upload Range: 17 - 18Mbps
  • Minimum Guaranteed Speed: 60.9Mbps
  • Current Line Speed (Download): 21Mbps
When I run a broadband speed test (wired - on wireless it seems about the same though) I get 19-20Mbps download, and 17Mbps upload. So my upload speed is fine, but my download is only about 1/3 the minimum guaranteed.
In my router settings (I'm using a BT Smart Hub 6 Business) it says this:
 Downstream sync speed:
68.02 Mbps
 Upstream sync speed:
18.97 Mbps
Any idea why I'm only getting under 20Mbps for download?
Thanks,
Tom
6 REPLIES 6
Thrall
Seasoned Pro
Fixes: 23
Re: Fibre speed only 1/3 of guarantee
Looks like the ‘current line speed’ profile on Plusnet’s side is set too low and capping your speeds. I suspect you have a static IP? This sort of profile generally only affects people who do due to network routing.
It may be worth raising a fault ticket at faults.plus.net and ask for that profile to be bumped up
wid
Yes, I do have a static IP - I'll try raising a fault as you suggest.
Thanks!
Thrall
Seasoned Pro
Fixes: 23
From reading other posts around here I believe the current line speed is also known as a ‘workplace connection profile’. It may help mentioning that on the fault ticket for when it’s picked up.
Fixes: 1,600
Hi Tom,
I've got the profile fixed for you now. It looks like the speed profile on your account dropped and was stuck for one reason or another after your fibre upgrade went through. Can you reboot your router and retest?
wid
Thanks! My account on the website now says:
  • Current Line Speed (Download): 68Mbps
Much more like it! Download speed tests now show 60Mbps download over Wifi.
I've marked the support case closed.
Thanks all!
Fixes: 1,600
Awesome! Let us know if there's anything else you'd need help with.
