Fibre speed less than expected
FIXED- Subscribe to RSS Feed
- Re: Fibre speed less than expected
02-09-2016 10:29 AM
Had my fibre connection for a few weeks now and was waiting for it to settle down as recommended. Upload speed is around 2mbps so ok but download is still around 15mbps so no better than ADSL was. Are there any other settings I need to change? Attach speed test results as advised...
Fixed! Go to the fix.
02-09-2016 10:38 AM
i suspect your profile has not been updated by PN, check what it says here - https://www.plus.net/my.html?action=data_transfer_speed
02-09-2016 10:43 AM
It says....
Estimated line speed:40Mb (This may vary between 73.6Mb and 80Mb) - Checked on 2016-07-02 18:40:04
Current line speed:16.6 Mb
02-09-2016 11:01 AM
02-09-2016 11:11 AM
Thanks. Just rerun BT Wholesale speed test and still says about 15mbps download. Will it take time to increase?
02-09-2016 11:15 AM
02-09-2016 11:20 AM
Yes but obviously didn't work properly. Have repeated and now shows 37mbps download so all ok. Many thanks.
02-09-2016 11:21 AM
