Fibre speed less than expected
rgilyead
Had my fibre connection for a few weeks now and was waiting for it to settle down as recommended. Upload speed is around 2mbps so ok but download is still around 15mbps so no better than ADSL was. Are there any other settings I need to change? Attach speed test results as advised...
7 REPLIES 7
delius21
Re: Fibre speed less than expected
i suspect your profile has not been updated by PN, check what it says here - https://www.plus.net/my.html?action=data_transfer_speed
rgilyead
It says....
Estimated line speed:40Mb (This may vary between 73.6Mb and 80Mb) - Checked on 2016-07-02 18:40:04
Current line speed:16.6 Mb
MatthewWheeler
Fixes: 479
I've just updated the profile for you.
If you disconnect then reconnect it should increase your speeds.
 Matthew Wheeler
rgilyead
Thanks. Just rerun BT Wholesale speed test and still says about 15mbps download. Will it take time to increase?
MatthewWheeler
Fixes: 479
Have you disconnected and reconnected?
 Matthew Wheeler
rgilyead
Yes but obviously didn't work properly. Have repeated and now shows 37mbps download so all ok. Many thanks.
MatthewWheeler
Fixes: 479
Glad to hear it.
 Matthew Wheeler
