Fibre speed fluctuating
- Fibre speed fluctuating
11-11-2016 8:16 AM
Hi guys
could someone please check my line is ok as I am getting continually fluctuating speeds whereby testing with Speedtest one minute it will be up in the 50Mb range and then test again and it will drop right down to 5-10Mb.this is done over wifi so not sure if it's a problem with the wifi or my fibre connection
thanks
chris
Re: Fibre speed fluctuating
11-11-2016 8:21 AM
Can you not test Wired ? Wifi tests will fluctuate
11-11-2016 8:25 AM
Yes I can do but can wifi fluctuate that much?as sometimes when I'm on iPad it all starts really slowing down.will test it later
cheers
11-11-2016 9:52 AM
