Fibre speed fluctuating
chri5hill
Hi guys
could someone please check my line is ok as I am getting continually fluctuating speeds whereby testing with Speedtest one minute it will be up in the 50Mb range and then test again and it will drop right down to 5-10Mb.this is done over wifi so not sure if it's a problem with the wifi or my fibre connection
thanks
chris
3 REPLIES 3
rongtw
Fixes: 12
Re: Fibre speed fluctuating
Can you not test Wired ?  Wifi tests will fluctuate
chri5hill
Yes I can do but can wifi fluctuate that much?as sometimes when I'm on iPad it all starts really slowing down.will test it later
cheers
Fixes: 291
Your line is testing fine so I'd recommend trying a wired connection as has been advised.
 Matthew Wheeler
