Fibre speed fallen by 10Mbps in last few weeks
VileReynard
Seasoned Pro
Fixes: 11
No changes have been made at my end.
As you can see from the associated graph, from Samknows, my actual speed achieved was 60 - 65 Mbps.
The current speed has been throttled - please reset my profile to 65+ Mbps
Attached are graphs of the last 6 months speed monitoring,
Two BT screenshots which indicate that my profile has been limited to 59.3Mbps
Please fix this.
Re: Fibre speed fallen by 10Mbps in last few weeks
You're going to fall within the acceptable limits of your line, so there isn't much Plusnet will be able to do.
Do you have access to your modem stats?
VileReynard
Seasoned Pro
Fixes: 11
Because I have a BT fibre modem, I don't have access to any modem stats.
Possibily, Plusnet are trying to shave off bandwidth in a cost cutting exercise...
Fixes: 21
This will be a tricky one for the reason AndyH has already mentioned, it's not even a 25% drop which could get counted as a fault.
It's not as simple as "resetting the profile" and the profile hasn't been limited to 59.3Mbps.
The IP profile is directly related to the current sync speed. It's not a banded speed AFAIK. So something has caused a drop in your sync speed.
See if you can identify which Type of Cabinet you are on.
What make of modem is it, and how long has it been on-line?
What's the results of pingtest.net? Also ping ntp.plus.net from a command prompt.
If you put your number into the DSL Checker it will tell you which Cabinet you are on (as well as your exchange which you know doubt know)..
VileReynard
Seasoned Pro
Fixes: 11
Thanks @Anotherone!
That's all useful information.
I would appear to have a Huawei 96/128 FTTC cabinet - however the cabinet number is sprayed on the telephone cabinet (which is definitely 15+ years old); the nearby FTTC (maybe 5 years old) cabinet has no number.
However, it might have worn off as my Plusnet account says I've had fibre since 25/01/2010.  Shocked
Never been this slow before.
I've attached the DSL checker display - which claims perfect speeds.
jeremy@hector ~ $ ping ntp.plus.net
PING ntp.plus.net (212.159.6.9) 56(84) bytes of data.
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=1 ttl=60 time=9.04 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=2 ttl=60 time=9.06 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=3 ttl=60 time=9.15 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=4 ttl=60 time=9.46 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=5 ttl=60 time=9.51 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=6 ttl=60 time=10.9 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=7 ttl=60 time=9.16 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=8 ttl=60 time=10.0 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=9 ttl=60 time=9.29 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=10 ttl=60 time=9.93 ms
^C
--- ntp.plus.net ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9013ms
rtt min/avg/max/mdev = 9.047/9.554/10.901/0.560 ms
Note: these pings are over a power-plugs connection which has a 3 - 4ms latency; the speed tests are over a wired connection to my router.
Fixes: 162
Quote from: vilefoxdemonofdoom
Those two statements contradict each other. We cannot alter the sync or the profile on a Fibre connection, nor would we if we could.
Sync:
Downstream Speed 61.3 Mbps
Upstream Speed 20.0 Mbps
 Chris Parr
 Plusnet Staff
VileReynard
Seasoned Pro
Fixes: 11
I haven't been getting any downloads of 61.3Mbps and even if I were, it would be considerably less than download speeds obtained only a few weeks ago.
Fixes: 21
You forgot to say what make of Modem it is Smiley
But apart from that, the Samknows results clearly show something isn't right. Even the sync speed is a good 10Mbps below the Range B Impacted estimates. The pings look fine.
VileReynard
Seasoned Pro
Fixes: 11
I've managed to raise a ticket.
Fixes: 21
So what's the latest?
VileReynard
Seasoned Pro
Fixes: 11
Still waiting - although the home page says they've answered my ticket - although they haven't.
If I add anything to it, I face a 3+ delay until it gets looked at.
So I thought I'd wait until 15th (that would be 6 days) before adding a stay alive message.  Smiley
Interestingly enough, my current line speed which normally doesn't change from one month to the next has increased by a modest 4Mbps in the last couple of days.
Perhaps I should re-title the subject line to Fibre speed fallen by 10 6Mbps in last few weeks
Fixes: 21
But it's gone down, even if it's now creeping up Crazy
Quote from: vilefox
Why? Tickets no longer go to the back of the queue if you add to them, that was fixed, remember.......then they got rid of tickets for most topics!
VileReynard
Seasoned Pro
Fixes: 11
I think I will wait until after the weekend - there won't be anyone in the office to look at my ticket.  Lips are sealed
