Fibre speed dropped nearly by half
lesclark13
Over the last few days my fibre speed has dropped from average 72Mbs to under 40Mbs.
Thats with everything disconnected but one computer which is  wired direct to router
BT test results
Results Image not loaded
1. Best Effort Test:
Download Speed : 36.86 Mbps
2. Upstream Test:
Upload Speed : 3 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
1 REPLY
Fixes: 193
Re: Fibre speed dropped nearly by half
It does look like your sync speeds are lower than we'd expect.
I see you've raised a fault online earlier today, our faults team will investigate this and get back in touch.
 Harry Beesley
