Fibre speed dropped by over 20mbit
FIXEDTopic Options
- Fibre speed dropped by over 20mbit
07-11-2020 10:14 PM
Today I've discovered my broadband has dropped from around 55-60mbit down to 30-35mbit. I'm using ethernet only to my Plusnet Hub One.
I've restarted the router, checked other devices (on wifi and ethernet) but no joy. I've attached the BT Wholesale speedtest performance test report.
Any help much appreciated!
Nathan
Fixed! Go to the fix.
Labels:
Message 1 of 2
(442 Views)
1 REPLY 1
07-11-2020 11:07 PM
After most of the day being quite slow, speed seems to be improving a bit so with any luck the problem will rectify itself. Can't find a way to edit/delete the thread but this no longer needs a response for now.
Message 2 of 2
(425 Views)
