Fibre speed decreasing throughout the day
Myfanwy365
I moved house about 5 weeks ago, had my Fibre Account switched over to the property on the 17th September.
Ever since that date i've had an odd pattern to my speed, generally 17Mbps at 6am when I leave for work, 6/7Mbps at 5:30pm when I return, at 9pm it's barely 2Mbps. Day in, day out this is the situation.
Example shown below, all using the SpeedTest app on my phone. Have checked using wired connection on my laptop with the same results
VRhpzWC
Have done a BTW test & further diagnostics, results below
22hQLKY
DSL Checker advises I should be able to reach speeds of at least 35Mbps
vulwVwI
If I go to - https://portal.plus.net/my.html?action=data_transfer_speed
I get the following
Phone exchange:CHESTER CENTRAL
Estimated line speed:40Mb (This may vary between 40Mb and 54.4Mb) - Checked on 2016-08-12 19:38:25
Current line speed:7 Mb
I'm getting slightly frustrated, have raised a query with support. But I can't see any reason why my speed should just drop rapidly throughout the day, it's appalling. Attempting to stream the NFL last week using GamePass & couldn't even watch on 360p without it buffering every 30 seconds
Are my settings correct, given i'm paying for Fibre I would imagine to be approaching somewhere over 25-30Mbps, as it is it looks like i've been capped or am being throttled in some way
Help???
6 REPLIES 6
bobminors
Re: Fibre speed decreasing throughout the day
This may not be relevant, but do you have your firewall turned on at the server end? (I don't mean the one inside the router, I mean the one you see at https://portal.plus.net/my.html?action=firewall&firewallPage=advanced ) If not, try turning it up to Max. It may be that there is a lot of unwanted traffic burning up your line capacity before it eventually gets blocked at your end by the router.
Myfanwy365
It was set to Off, i've never touched it. Set it to High now.
Will restart router, wait a minute then try again
bill888
Champion
Fixes: 38
Your IP profile of 17.97 mbps seems low compared to the estimates provided by the DSL checker.
What router are you using?
If it is a Hub One, can you log into the hub at 192.168.1.254
Go to Troubleshooting -> Helpdesk.  What is reported for:
Data Rate
Noise Margin
Line Attenuation
Is your router connected to a filtered master BT socket, or are you using microfilters on a telephone extension?
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Myfanwy365
Hi, Yes it is a Hub One
6. Data rate: 2000 / 18878
7. Maximum data rate: 3009 / 19080
8. Noise margin: 7.3 / 6.2
9. Line attenuation: 33.6 / 22.6
10. Signal attenuation: 20.5 / 18.3
I have the hub plugged in to what I presume is my master socket, it's not an NTE5 however. Just looks like a normal phone socket, the one closest to my door. Have tried a number of sockets with the same results.
I am using a microfilter as well
bobminors
Okay, forget my firewall suggestion, turns out that's a red herring. Your line quality is poor. There is noise on the line that is varying through the day, and the first thing that springs to mind is that it is caused by crosstalk from other fibre users connected through adjacent cores of the same cable under the road back to the cabinet. The more your neighbours use their broadband, the more of their signals leak across into your wires and the harder it is for the equipment connected to your line to make out your signal from the background chatter.
bill888
Champion
Fixes: 38
The low 'Data rate' is not being caused by an excessively high noise margin.  It is still less than the estimated 20 mbps impacted rate quoted by the DSL checker.  I think the next step is to report the problem to Plusnet.
http://faults.plus.net/
Hopefully an engineer will fit a new NTE5 master socket (and filtered face plate) too.
