Fibre speed and phone number is wrong on plusnet portal
NoZephy
Any reason I'm seeing a completely different number than the one I currently pay for? Huh
1 REPLY 1
Chris
Legend
Fixes: 169
Re: Fibre speed and phone number is wrong on plusnet portal
From the look of that, someone had to perform some manual updates to get your account in to the right status. That shouldn't cause you any issues at all as the number is correct on the main area of your account, it's just a cosmetic issue.
