Fibre speed 20 mb lower than estimated
Jonejayc
Hi had fibre installed yesterday , engineer said line is 40/2 , as I ordered 80/20 live chat with advisor said  system set up wrong wait 12 hours will all be good . Today have 36 down 18 up estimated line speed 59 mb  , can a mod look into this thanks
Fixes: 167
Re: Fibre speed 20 mb lower than estimated
Should be sorted now, you might need to disconnect/reconnect for the new speeds to come through.
 Chris Parr
 Plusnet Staff
Jonejayc
Thanks Chris hitting 65mb  now all is good
