Fibre slower than my previous non-fibre broadband
Bluepanido
I should apparently be getting 37mbps, but I'm getting awful speeds, generally between 3 to 5 mbps. This is slower than I had with Sky, on non-fibre broadband, before I switched to Plusnet Fibre at the end of December. I raised a fault with Plusnet, who emailed a few days later (on Friday) to say that their 'supplier' had fixed the fault. However, the fault has not been fixed, so I updated the ticket yesterday to say this, but have heard nothing since. Slow loading of web pages and buffering is not why I joined Plusnet.
Bluepanido
Re: Fibre slower than my previous non-fibre broadband
Do PlusNet staff answer threads on here?
rongtw
Fixes: 12
Mostly. 👍
Fixes: 78
Hi Bluepanido,
Sorry to see you've been having problems with connection speeds.
Before we look at progressing the fault can I just double check with you that the latest set of speed tests were done over ethernet?
 Adam Walker
Bluepanido
Yes it was over ethernet. Just tested it now and got 3.37 mbps.
Fixes: 78
Thanks for that, I've just added an update to the fault ticket for you.
 Adam Walker
