Fibre slower than 5MB - help please
- Re: Fibre slower than 5MB - help please
13-05-2017 10:45 PM
However download speed only 5MB
Was ~24mb when we changed over to plusnet.
Can you please check speed?
14-05-2017 5:15 PM
If there was a fault on the line, the BT engineer should have done a SNRM reset. Might need to raise a fault report to get this fixed.
Run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
Also find your CURRENT SPEED (PlusNet line profile) from the PlusNet user portal - you will need to log in.
15-05-2017 11:58 AM
