Fibre slowed right down.
- Fibre slowed right down.
14-01-2018 7:17 PM
When I first moved to fibre, I was getting 40mps. Now I'm only getting 15mps. Can't check with a wired connection. Any thing I can do?
Re: Fibre slowed right down.
15-01-2018 11:41 AM
It could be a wireless issue so try the following:
1. Get an app such as WiFi Analyser on your phone and use it to make sure that you do not have a conflicting neighbours transmission on the same frequency. Check both at the location of your router and where you use your mobile devices. If there is a strong signal neighbour's signal on the channel you are using then go into the router advanced wireless properties and manually select a clearer channel.
2. Separate the 2.4 and 5 GHz bands by again going into the advanced wireless properties in your router, select the 5GHz tab, click on the button that asks is you want to sync with the 2.4GHz band to remove the sync then rename the 5GHz band by adding 5 after the SSID. You then can try both bands (providing your mobile device supports 5GHz) to find the best.
If this fails then I'm afraid that you are going to have to report a fault. Can you not borrow a laptop or netbook of some sort to go through the proper wired test procedure from the master socket and hence avoid the risk of a £65 false call out charge?
17-01-2018 2:30 PM
I'm sorry to hear you're experiencing speed problems @Porksley
Our tests are finding a loop condition, which is basically like a short circuit somewhere. This type of issue is usually caused by equipment or internal wiring connected to your phone line.
Can you run through the steps here and let us know how you get on? -Anoush
