Fibre slow and doing a check has shown FTTP is not being directed to my house
- Re: Fibre slow and doing a check has shown FTTP is...
02-01-2015 6:48 PM
Re: Fibre slow and doing a check has shown FTTP is not being directed to my house
02-01-2015 6:53 PM
From looking at your account it looks like you're on FTTC not FTTP, therefore the comment about FTTP from the checker can be ignored. FTTC is Fibre To The Cabinet, which is the fibre service we sell via our website. FTTP is Fibre To The Premises which is not something we advertise.
What speeds are you currently seeing as a line test is showing you connected at the speeds we'd expect (40Mb/s downstream).
02-01-2015 7:04 PM
Thanks for the quick reply. These are the results:
(With only my laptop connected by a Ethernet cable)
Download speed: 38.52
Upload Speed: 13.47
Ping Latency: 42.38
02-01-2015 7:06 PM
02-01-2015 7:12 PM
02-01-2015 10:42 PM
It might be worth trying a different wifi channel - in case you are using the same channel as your neighbors. You need to log into the router web interface to change it.
EDIT - forget Inssider - I thought it was free, it isn't
02-01-2015 11:42 PM
03-01-2015 5:21 AM
03-01-2015 11:41 AM
18-02-2015 11:29 PM
