Fibre running at half the speed I was promised
Lynds777
Current speed is showing in member centre as 21Mb, I was promised 44Mbps. I have carried out all the checks in Plusnet Support, please fix this
1 REPLY
Fixes: 236
Re: Fibre running at half the speed I was promised
Our tests aren't showing any particular cause for this.
If you can raise a fault here we can get that looked into.
 Matthew Wheeler
