Fibre randomly disconnects throughout the day
hibeejo
Wonder if anyone can help, joined fibre ulimited back in Nov/Dec and had no issues untill the last 4/6 weeks, basically the internet drops of at total random times, I usually find this alot more frequently at weekends.
the router just drops to the red flashing light, resets and good to go, I usually find that if its done it once it more than often will disconnect 2/3/4 more times  faitly close to each other and will eventually settle.
can anyone assist.
Adl3r
Re: Fibre randomly disconnects throughout the day
Hi. Just new here myself, I was directed to this thread (linked below) by a helpful member. This may have something to do with your problem. Its to do with uploading on the 40/2 package using hub one pn router
https://community.plus.net/t5/Fibre-Broadband/Plusnet-fibre-broadband-does-not-cope-with-uploads-and...
Hope this helps.
Good luck.
figgley
Some people on here say that Bob Pullen-your-leg can apply a patch to your router, mate.
It all sounds rather kinky to me but then that may just be the way my mind works.
