Fibre profiling
Toast3000
Fibre profiling
Hello,
I was wondering if one of the helpful forum team could take a quick look at my fibre profile.
When my line was installed I was getting 10-12ms pings off to UK based websites and the full 40mbps my package allows. However it has deteriorated in regards to both stats; my ping is now 30-33ms and my speeds return around 30mbps.
I think I made a pretty dum mistake in turning my equipment on and off at least twice a day, so the exchange may have assumed I was having problems and dialled my profile back to compensate. I'm on an open reach modem so can't check the exact figures sadly.
I've left the equipment on now for 5 days, with no change. Happy to wait longer if needed but forums are always worth a shot Smiley
Can anyone take a look?
Thanks!
Edit : I've just read the DLM article on here. Looking at that I will just need to sit tight, until the system picks up.  Cheesy
nigel1971
Re: Fibre profiling
Yes don't turn off the modem, just the router if you have too.
MattyC
Champion
Fixes: 46
Re: Fibre profiling
Hi Toast3000,
Stability is key here, so unfortunately it's going to be a case of sitting tight. The profiles should fix themselves in due course.
Matty
Toast3000
Re: Fibre profiling
I thought so, I will wait. The connection is very stable regardless, well done Smiley
