Fibre problems
- Fibre problems
Fibre problems
10-05-2017 1:30 PM
i have been noticing over the last week or so that internet has been running slow and websites are intermittently responding, When checking the Router for errors is see a lot of the following.
Dones anyone else have an issue with the router endlessly Client disassociated and then Client associated
Re: Fibre problems
10-05-2017 2:13 PM
Hi Mjnorman01 and welcome to the Community Forums,
I've had a check into your connection and although there have been a few drops over the last few days it doesn't seem to be anything causing by issues on the line as when checking your connection to the router everything is looking spot on.
The speed we are getting to the router is:
71.2 Mbps download
16.1Mbps upload
With no trace of errored seconds.
Can I ask, is it mainly wireless devices you use? As it could be solely just be the wifi signal being interfered with which can be tweaked for improvements.
Kind Regards,
Ben
Re: Fibre problems
10-05-2017 2:35 PM
Hi Ben
i have 3 PC's connected Via Ethernet and the normal Ipads/Phones Wireless.
This is my router error log for the last 15 min.
14:33:13, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:33:03, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:32:50, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:32:40, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:32:26, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:32:16, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:32:03, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:31:53, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:31:42, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:31:32, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:31:18, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:31:08, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:30:55, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:30:45, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:30:31, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:30:21, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:30:11, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:30:01, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:29:47, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:29:37, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:29:23, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:29:13, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:29:00, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:28:50, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:28:40, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:28:29, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:28:16, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:28:06, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:27:52, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:27:42, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:27:28, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:27:19, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:27:08, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:26:58, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:26:51, 10 May. | IN: BLOCK [16] Remote administration (TCP [218.78.213.142]:24384- >[146.90.125.155]:22 on ppp3) |
14:26:44, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:26:34, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:26:21, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:26:11, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:25:57, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:25:47, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:25:37, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:25:27, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:25:13, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:25:03, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:24:49, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:24:40, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:24:26, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:24:16, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:24:05, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:23:55, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:23:42, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:23:32, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:23:18, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:23:09, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:23:05, 10 May. | (90120.080000) Device disconnected: Hostname: Samsung- Galaxy- S7- edge IP: 192.168.1.62 MAC: d8:c4:6a:a7:04:1f |
14:23:05, 10 May. | (90120.080000) Device disconnected: Hostname: LAPTOP- V6NDFEJU IP: 192.168.1.106 MAC: 98:54:1b:c6:36:8a |
14:23:05, 10 May. | (90120.070000) Device disconnected: Hostname: Charisses- iPad IP: 192.168.1.105 MAC: e0:b9:ba:ed:35:39 |
14:23:05, 10 May. | (90120.070000) Device disconnected: Hostname: CharissesiPhone IP: 192.168.1.104 MAC: b0:70:2d:9d:36:ff |
14:23:05, 10 May. | (90120.070000) Device disconnected: Hostname: LAPTOP- OG7DLC47 IP: 192.168.1.103 MAC: 84:ef:18:00:3e:7b |
14:23:05, 10 May. | (90120.060000) Device disconnected: Hostname: GearS3- 85AA IP: 192.168.1.102 MAC: 1c:23:2c:fd:85:ab |
14:23:05, 10 May. | (90120.060000) Device disconnected: Hostname: DESKTOP- NAB8N48 IP: 192.168.1.101 MAC: 28:e3:47:d2:ed:01 |
14:23:05, 10 May. | (90120.040000) Device disconnected: Hostname: Matt- Tablet IP: 192.168.1.100 MAC: c0:21:0d:18:1f:40 |
14:23:05, 10 May. | (90120.040000) Device disconnected: Hostname: Alexs- iPhone IP: 192.168.1.99 MAC: dc:41:5f:a5:28:79 |
14:23:05, 10 May. | (90120.040000) Device disconnected: Hostname: DESKTOP- CFBP7G7 IP: 192.168.1.97 MAC: 2c:33:7a:07:bd:7d |
14:23:05, 10 May. | (90120.030000) Device disconnected: Hostname: Unknown- 10- 08- c1- 30- ee- c7 IP: 192.168.1.96 MAC: 10:08:c1:30:ee:c7 |
14:23:05, 10 May. | (90120.030000) Device disconnected: Hostname: Scotts- iPhone IP: 192.168.1.63 MAC: 80:ea:96:94:a5:45 |
14:23:05, 10 May. | (90120.030000) Device disconnected: Hostname: iPhone- 2 IP: 192.168.1.54 MAC: 2c:33:61:b1:ca:16 |
14:23:05, 10 May. | (90120.030000) Device disconnected: Hostname: Jonnys- Iphone IP: 192.168.1.53 MAC: ec:35:86:ca:79:ba |
14:23:05, 10 May. | (90120.030000) Device disconnected: Hostname: Laptop- SD10 IP: 192.168.1.86 MAC: e0:94:67:85:75:b9 |
14:23:05, 10 May. | (90120.020000) Device disconnected: Hostname: android- 7e947910f3aa721a IP: 192.168.1.84 MAC: 84:8e:df:14:03:18 |
14:23:05, 10 May. | (90120.010000) Device disconnected: Hostname: DESKTOP- 929B39Q IP: 192.168.1.81 MAC: 68:94:23:f6:43:89 |
14:23:05, 10 May. | (90120.010000) Device disconnected: Hostname: Jennis- iPhone IP: 192.168.1.76 MAC: 2c:f0:a2:5e:bb:ad |
14:23:05, 10 May. | (90120.010000) Device disconnected: Hostname: DESKTOP- 6GILI1I IP: 192.168.1.73 MAC: 80:a5:89:ad:a4:c1 |
14:23:05, 10 May. | (90120.000000) Device disconnected: Hostname: iPhone IP: 192.168.1.67 MAC: 60:03:08:32:34:a1 |
14:22:56, 10 May. | (90110.680000) Device disconnected: Hostname: Samsung- Galaxy- S7- edge IP: 192.168.1.62 MAC: d8:c4:6a:a7:04:1f |
14:22:56, 10 May. | (90110.680000) Device disconnected: Hostname: LAPTOP- V6NDFEJU IP: 192.168.1.106 MAC: 98:54:1b:c6:36:8a |
14:22:56, 10 May. | (90110.680000) Device disconnected: Hostname: Charisses- iPad IP: 192.168.1.105 MAC: e0:b9:ba:ed:35:39 |
14:22:56, 10 May. | (90110.660000) Device disconnected: Hostname: CharissesiPhone IP: 192.168.1.104 MAC: b0:70:2d:9d:36:ff |
14:22:56, 10 May. | (90110.660000) Device disconnected: Hostname: LAPTOP- OG7DLC47 IP: 192.168.1.103 MAC: 84:ef:18:00:3e:7b |
14:22:56, 10 May. | (90110.660000) Device disconnected: Hostname: GearS3- 85AA IP: 192.168.1.102 MAC: 1c:23:2c:fd:85:ab |
14:22:56, 10 May. | (90110.660000) Device disconnected: Hostname: DESKTOP- NAB8N48 IP: 192.168.1.101 MAC: 28:e3:47:d2:ed:01 |
14:22:56, 10 May. | (90110.660000) Device disconnected: Hostname: Matt- Tablet IP: 192.168.1.100 MAC: c0:21:0d:18:1f:40 |
14:22:56, 10 May. | (90110.660000) Device disconnected: Hostname: Alexs- iPhone IP: 192.168.1.99 MAC: dc:41:5f:a5:28:79 |
14:22:56, 10 May. | (90110.650000) Device disconnected: Hostname: DESKTOP- CFBP7G7 IP: 192.168.1.97 MAC: 2c:33:7a:07:bd:7d |
14:22:56, 10 May. | (90110.640000) Device disconnected: Hostname: Unknown- 10- 08- c1- 30- ee- c7 IP: 192.168.1.96 MAC: 10:08:c1:30:ee:c7 |
14:22:56, 10 May. | (90110.640000) Device disconnected: Hostname: Scotts- iPhone IP: 192.168.1.63 MAC: 80:ea:96:94:a5:45 |
14:22:56, 10 May. | (90110.640000) Device disconnected: Hostname: iPhone- 2 IP: 192.168.1.54 MAC: 2c:33:61:b1:ca:16 |
14:22:56, 10 May. | (90110.640000) Device disconnected: Hostname: Jonnys- Iphone IP: 192.168.1.53 MAC: ec:35:86:ca:79:ba |
14:22:56, 10 May. | (90110.640000) Device disconnected: Hostname: Laptop- SD10 IP: 192.168.1.86 MAC: e0:94:67:85:75:b9 |
14:22:56, 10 May. | (90110.630000) Device disconnected: Hostname: android- 7e947910f3aa721a IP: 192.168.1.84 MAC: 84:8e:df:14:03:18 |
14:22:56, 10 May. | (90110.620000) Device disconnected: Hostname: DESKTOP- 929B39Q IP: 192.168.1.81 MAC: 68:94:23:f6:43:89 |
14:22:56, 10 May. | (90110.620000) Device disconnected: Hostname: Jennis- iPhone IP: 192.168.1.76 MAC: 2c:f0:a2:5e:bb:ad |
14:22:56, 10 May. | (90110.620000) Device disconnected: Hostname: DESKTOP- 6GILI1I IP: 192.168.1.73 MAC: 80:a5:89:ad:a4:c1 |
14:22:56, 10 May. | (90110.610000) Device disconnected: Hostname: iPhone IP: 192.168.1.67 MAC: 60:03:08:32:34:a1 |
14:22:56, 10 May. | (90110.600000) Device disconnected: Hostname: et9x00 IP: 192.168.1.78 MAC: 00:16:b4:05:fa:fc |
14:22:54, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:22:44, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
14:22:34, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client disassociated |
14:22:24, 10 May. | ath00: STA 00:26:ab:26:98:6e IEEE 802.11: Client associated |
Re: Fibre problems
10-05-2017 2:44 PM
@mjnorman01 - Out of curiosity how many people are on your network normally?
Re: Fibre problems
10-05-2017 2:50 PM - edited 10-05-2017 2:52 PM
not a lot :-).
3 to 4 people on Ipads/Iphones
3 IpTV boxes
2 Pc's
1 Laptop
and a gaming mad person who use to suck up all the bandwidth until we got Fibre....
Re: Fibre problems
10-05-2017 2:56 PM
OK, So I assume you'll know about all of the people and devices mentioned in the log you posted. The WiFi is secure isn't it?
Re: Fibre problems
10-05-2017 3:00 PM
Yes it is:-)
all the devices are accounted for.... However i only have 9 devices connected all the time, the rest are Guest that come over.
3 teenagers with lots of friends who pop over and connect into the wifi.
i do have my DHCP lease time set to the max because i was getting a lot of IP address renewing errors in the log file.
Re: Fibre problems
10-05-2017 3:10 PM
If this router supports IPv6, then turn it off, (as I assume you are not part of IPv6 trial,) along with the IPv6 support in your devices (if you can be bothered).
Re: Fibre problems
10-05-2017 3:23 PM
cant see anywhere where you would disable IPV6
only ULA wich is recommend (according to the router) as enabled.
