Fibre plus
Fibre plus
I have switched to fibre plus now my download speed has halfed
5 REPLIES 5
Legend
Fixes: 168
Re: Fibre plus
Hi there, welcome to the forums.
Sorry that you're experiencing issues with your speed.
Your line estimates are:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 64.9 48.4 19.5 13.5 40.7 Available -- Yes Yes --
And your line is connected at 53.4Mb/s, so well within that range:
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 53.4 Mbps
Upstream Speed 19.7 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 595.4
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Time Stamp 2017-06-06T09:30:00
What speeds are you getting on a speedtest and is that over a wired or wireless connection?
Re: Fibre plus
Today It's better
Wired
it's
ping 22
download 35.75
Upload 18.22
Wireless
Ping 23
download 22.20
upload 17.98
On Saturday it was
Wired
ping 26
download 16.84
upload 2.10
Fixes: 931
Re: Fibre plus
Your throughput still looks a bit on the low side.
Please can you run a BT speedtest for me, using the wired connection, ensuring that no other devices are connected to the router (wired or wireless), and there are no open background tasks on the PC you're using.
EDIT: Make sure you complete the further diagnostics too, thanks.
Re: Fibre plus
Getting through bt speedtest
50.31 download
14.92 Upload
25.13 ping
Fixes: 931
Re: Fibre plus
For your line estimates and current sync rate, that's looking a lot better.
I'd advise to monitor this and if the speed drops, report the fault to us at http://faults.plus.net
