Fibre plus keeps slowing down
- Fibre plus keeps slowing down
24-08-2020 6:51 PM
hi,
I have the top speed fibre and lately it has started getting slower and slower. If I switch off the router for a minute when it comes back it is full speed again. I thought that you should leave the router on all the time or you get problems?
Chris
Re: Fibre plus keeps slowing down
27-08-2020 10:19 AM
Hi @Chrisvesey. I'm sorry to hear about this - we do recommend leaving the router on at all times but would recommend the occasional reset, especially if there are a lot of devices connected, to refresh the connection.
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net.
