Fibre order question
KaotiK
Hey, so finally have fibre in the area after years of waiting! so i have made the product change online for Fibre extra, new router etc.
Im just wondering how long it usually takes for it to change over from standard 8m adsl to Fibre? and will i also get my new router straight away?
cheers
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Fibre order question
Depending on local engineer availability it takes anywhere from 5 working days, to several weeks. I'll go check shortly and see when your order is committed for.
The router is sent to arrive a few days before the activation, but I'll manually kick that along.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 159
I've created a support ticket on your account and emailed confirmation of this to you with the date of your order.
 Chris Parr
 Plusnet Staff
KaotiK
awesome! thank you!
KaotiK
I assume i dont plug my new router in until the fibre is all setup right?
Fixes: 149
The Hub One works on standard broadband so you can set it up when you receive it.
 Matthew Wheeler
KaotiK
ah ok cool, then once fibre is set up it will automatically happen i wont have to do anything?
Fixes: 149
That's correct.
There'll be some downtime on the day whilst the engineer carries out the work but after that you should be receiving fibre speeds.
 Matthew Wheeler
KaotiK
Hey, i have setup my Hub one router now. However my connection seems to be dropping regulary with it at the moment? is there a setting i need to change or something?
KaotiK
Have had to switch back to my old router as it was dropping constantly... hopefully there is a solution as looking forward to fibre but with the drops like that its no good
KaotiK
hey, Is everything still on course to be completed tommorow?
