Fibre not working yet
- Fibre not working yet
3 weeks ago
Re: Fibre not working yet
3 weeks ago - last edited 3 weeks ago
Hi @valnetinazou. I'm sorry to hear that you've been unable to get online following your activation. I can confirm that the broadband activation order has fully completed.
Testing your line hasn't picked up any faults from here but looks to show that the line isn't detecting your router at all at the moment:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0008 | ||||
Description | Modem is out of sync and fault is most likely to be in the home environment | ||||
Main Fault Location | OK | ||||
Sync Status | Out Of Sync | ||||
Downstream Speed | 0.0 Mbps | ||||
Upstream Speed | 0.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | Unknown | ||||
Voice Line Test Result | Pass | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Technology | VDSL | ||||
DP Type | External | ||||
Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2020-12-18T15:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 39.9 Mbps | 39.9 Mbps | 39.9 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 352.3 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-12-31T15:00:33.348+00:00 | 2020-12-31T15:15:33.348+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 900 | 0 |
As this is the case, it's likely that there's been an issue with how the router has been set up and we'll need to run through some troubleshooting steps to try and get to the bottom of this. I'd recommend starting with basic checks here. If that doesn't resolve the problem the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the connection improves. This rules out internal wiring, faceplates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here.
3 weeks ago
Thank you for your reply. My master socket doesn’t have a test socket so I can’t do that 😣
3 weeks ago
Hi @valentinazou, would it be possible for you to attach a photo of your socket and setup so we have a better idea of where the issue could be occurring?
3 weeks ago
Hi, here are the pictures! let me know if they're clear enough, thanks
3 weeks ago
@valentinazou are you sure that's the master socket ? It doesnt have either a BT or Openreach logo on it. Even most of the old style sockets had logos.
Are there any other phone sockets anywhere ? Might be worth trying to trace where the phone line comes into the house and see if there are any sockets hidden away
2 weeks ago
2 weeks ago
Any unusual characters in your username / password ?
2 weeks ago
2 weeks ago
Outside the ranges A-Z (upper & lower case) and 0-9 some characters are unusable.
2 weeks ago
2 weeks ago - last edited 2 weeks ago
If your modem/router can’t log in to the Plusnet system then it’s never going to work.
This would confirm comment made by @EmilyD
2 weeks ago
It’s the username / password used in your account.
Then follow these instructions posted on an earlier thread by one of the support team :
1. Go to the router's homepage at http://192.168.1.254
2. Click on the Advanced Settings tab
3. Type in the admin password found from the back of the router and click the OK button
4. Click on the Continue to Advanced Settings button then the Broadband tab
5. If there's a Disconnect button, click that
6. Change the username to the broadband username in the format of username@plusdsl.net If you can't remember this I'd check for any emails we've sent you for example an email with you bill on as we'd add the username to the top of the email.
7. Type in the account password, this can be reset here: https://www.plus.net/forgotpassword/ if needed.
8. Hit the Connect button.
2 weeks ago
