Fibre not working at all
- Fibre not working at all
02-08-2019 9:10 PM
I thought it might be the cable so rushed to curry’s and bought a new one. It looks like it’s the box. The guy who fitted it taped it with double sided tape and its hanging off the wall with exposed wire. It took me the best part of 40 minutes to move two wardrobes so am hot and I would add that the Plusnet one router it total rubbish and had been from day one. I bought a very expensive Netgear router which I can’t use as have no actual internet to plug it into. Fed up is not the word. Need help.
Message 1 of 2
(469 Views)
1 REPLY 1
Re: Fibre not working at all
03-08-2019 10:30 AM
Hi @mic100, sorry to hear you're experiencing problems with your connection.
Please could you report this over at https://faults.plus.net and let us know once you've done this, we'll then be able to get this raised with our suppliers and get an engineer appointment booked in for you.
Message 2 of 2
(433 Views)
