Fibre modem keeps dropping internet connecton
daro2096
Having an intermitten fault. New fibre modem keeps dropping connection. Happened several times today. Watching a video on my smart tv from my computers hard drive and the network keeps going down.
Fixes: 5
Re: Fibre modem keeps dropping internet connecton
<img src="http://community.plus.net/visualradius/generated/image14261874927029.png"/>
The connection was looking very healthy until the logs seen above. Has anything changed in that time?
Those drops, whilst they could be problematic, shouldn't cause the problems that you see. It would be worth checking to see if you see if issues persist if you use a wired connection as well just to be sure.
 Tony T
daro2096
Wired connection at all times. When outrages occurred the lan1 light wasn't lit.
I have been using divx sharing. Connection dropped a few times whilst watching a video stored on my hard drive on my smart tv. Getting frustrating. Internet connection also down at the same time. Don't see how watching something on my local network would cause an outrage on my net connection.
daro2096
Can you get a BT engineer to come out and check the modem and line please? Already had 3 outrages this morning and I have only been up a couple of hours.
Fixes: 163
We'd need you to open a fault ticket so we can do some testing on the line and ensure that the troubleshooting tests asked for are performed. You can do this at https://faults.plus.net
 Chris Parr
 Plusnet Staff
daro2096
Had 5 drops of internet connection in just the last hour.
Fixes: 62
what was the result from the fault ticket you were asked to open a week ago
daro2096
Quote from: Chris
Fault ticket opened.
daro2096
Quote from: Oldjim
Was hoping the problem would go away on its own.
daro2096
Had the modem replaced, had new router sent, even changed the cable between modem and router(a cable I know works) and the router is still disconnecting.
Still having problems. Can't have had 2 faulty routers can I?
daro2096
I have gone back to my old non-plusnet router. Turns out it works with the bt fibre modem.
discodas
I have also had issues over dropped connection have been told issues at exchange, but I also have wifi connection issues from router it drops a few time in quick succession, and nothing recorded on the log. Strange as for the first 10 days during training nothing all great then suddenly all hell breaks looseHuh?Huh
Was it straight forward to try / use your old router I  have a HH2?
daro2096
My old router is a Cisco Linksys WRT120N router. Changed it to pppoe and I just put in my username(ex: username@plusdsl.net) and my password. Manually typed in the primary, secondary and 3rd IP addresses and hit save settings and I was good to go.
