Fibre just installed, initial results.
helidan
Just had Fibre installed, these are my initial performance results.
All4One
Re: Fibre just installed, initial results.
You probably need your profile updating PN side if just installed today.
helidan
thought it might be something like that, cheers!
Fixes: 188
I'm just looking into this for you now.
For some reason your account change hasn't completed.
I'll update this thread once I've changed it manually for you.
 Matthew Wheeler
helidan
Thank you!
Fixes: 188
Apologies for the delay but that should now be sorted.
If you log into your router and disconnect or reboot it and you should see a increase.
 Matthew Wheeler
helidan
Yep, speeds seem good now!  Thanks!!
Great support from Plusnet as always Smiley
Fixes: 188
Fantastic.
Glad to see that's done the trick.
If you have any further issues please let us know.
 Matthew Wheeler
