Fibre installed today... Really slow speeds, normal?
- Re: Fibre installed today... Really slow speeds, n...
05-10-2015 10:00 PM
Anyway i had the engineer come today and installed new Master socket etc and connected up my router and modem. I signed up fibre unlimited extra. The engineer stated my property is not far from the outside box therefore I should get max speeds. My initial speed test was 79Mbps! This is a huge improvement from 1Mbps I was getting with BT broadband. I performed 2nd speed test and this came up as 97Mbps. At this point I'm over joyed. But... Some hours later I tried showing my friend my new speed but the speed test was only coming back at 17Mbps. I performed several tests but they are all on average 17mbps.
I don't want to sound ungrateful because it's more then what I was getting with BT, and I understand speeds will go up and down for the first 10 days after instal but from 97Mbps to 17Mbps?! Is that normal?
Re: Fibre installed today... Really slow speeds, normal?
05-10-2015 10:11 PM
Sync speed?
05-10-2015 10:16 PM
You could try Chat or wait for it to be picked up here
05-10-2015 10:26 PM
I didn't want to contact plusnet if this is normal, but im guessing the speed is not meant to drop that much, so i will need to contact them tomorrow.
06-10-2015 12:16 AM
06-10-2015 3:44 PM
PS. If your trying to avoid congestion/speed related issues on a BT connection it probably wasn't the best idea to go to BT's side kick project...
Sorry to break this news But Plusnet uses the same connections as BT... it only splits when it reaches London...
It looks like you might be suffering with exchange congestion which will affect anything using BT's networking equipment, the only ISP's avoiding that would be ones using there own equipment at the exchange such as Sky, TalkTalk......
I could be wrong though, and you could have a line fault of some sort, or it could be something to do with issues on Plusnet's network, there is many possibilities.
06-10-2015 3:51 PM
06-10-2015 5:34 PM
Quote from: The I wonder if this is exchange congestion...
06-10-2015 5:35 PM
Quote from: Starmans I did read the initial post and I didn't see if mentioned but you've done the speed test but was that completed via a wired Ethernet connection not over Wi-FI?
06-10-2015 9:46 PM
Quote from: Kiritpatel My internet with BT was just standard broadband, when i signed up to plusnet the guy who took the order said my line was capable of the highest speed, upto 80mbps and said there wouldnt be any problems proving me with that speed.
Whether or not your Broadband with BT was Standard or Fibre, they both use the same equipment at the exchange, the only difference is the link between you and the exchange.
